Build a box or replace toilet?
19 Jun 2024
I replaced my bathroom floor and in the process, broke my 20+ year old toilet. I've fit the pictured toilet but it's a 17-18cm gap to the wall, and causing the cistern to lean forward.
Should I have a box built around it, or replace it all? It's close cistern and others I've found won't reach the gap.
Can I replace it with a low level? Thank you
Make a box and fit against wall. Fit cistern to that.
Hi Wayners, thanks for reply. Will a box be enough to secure it in case someone leans back on it?
In your experience, how much does it cost to build a box like that?
You'll get a little further back by using one of these:
Without breaking up the floor, (the only way to make perfect) make a box from 22mm MDF and sand and paint it well.
That flexible connector is a liability with the bend on it, and needs attention!
John :)
John :)
Hi John, thanks for the info. Am getting quotes for the box behind it.
Can you elaborate more on the flexible connecter? Why is it a liability and how can I not have a bend in it?
Thank you,
Matt
Looking at the flexible pipe, I see an isolator valve which is great but the pipe seems to take a sharp 90 deg bend, even maybe with a kink?
These things - work of the devil really but they are often used - need a good smooth run to keep them safe. I've had one burst - not for any particular reason that I could see and it was WRAC approved - so I don't like them!
I'd suggest a 90 deg compression bend after the isolator and fix the flexy to that.
A flush valve with an internal drain to the pan takes away the need for an overflow pipe which you may like to consider, unless it's already there.
Regards
John :)
Regards
John :)
Hi John, thanks very much for lengthy reply.
Just had another look at the flexy and I think the angle of the top-down photos makes it look worse. From the side it's not kinked but does take a turn so I will take on your suggestion!
The overflow pipe is now out of use as the new flush valve has the internal drain, but I appreciate the extra advice.
Matt :)
