Hi guys. Just questioning a couple of things on our house designs. We have a brick wall on the upstairs floor that forms a corridor to the bedrooms. It's 4.5m high so quite substantial weight and is largely just being supported by the floor slab which is 12cm thick 2 layer x 10mm wire reinforcement at 15cm spacings. The wall starts and ends on perpendicular beams and there is 1 other perpendicular beam that passes under it 2.5m in on one end. Is this OK? Designs are attached so you can see the corridor highlighted and the beams. Thanks
