Building a step, paving slab overlap question?
15 May 2013
Im after a bit of advice on building a step. Ive dug down and tampered the mud, added some concrete at roughly 4inches thick. Ive laid some building blocks on their side (4inch wide 7nm).
Im wanting to put paving slabs on top (45cm by 45cm). Should the paving slabs over lap the blocks a bit?
Thanks for your help
I always put a small overhang in, although I've just redone some steps in someones garden when they didn't want the overhang put back.
The slabs were nearly 30 years old and one of their friends stood on the edge and it gave way causing him for fall down the steps.
However I still put a 20mm overhang in with the new slabs as it would have meant cutting about 40 of them.
Thanks for the replies. Im going to add a 15-20mm overlap
I'm soon to be doing this and wondered what you do with the joints between the slabs on the overhang since there will be just air beneath the slabs at that point?
Cheers,
Ed
