Hi, i'm looking for some bricklayers advice.
I'm building an attached garage as above, its not big but it'll have its uses. Anyway the problem is how to block/ brick up the front section between the garage door and the house, i've got wall starters kits at the ready and wall tis, however the width is 340mm, so my question is what should i use to brick this up, i cant use concrete block as it not a full block should i use facing brick in the full section up to the lintel, its a 100mm 7n block/100mm cavity/100mm block. The bottom courses are facing brick to match existing.
Any advice will be much apprieciated
Cheers martin
Cheers martin
