Planning a side extension on house below
As you can see the chimney is on the side.
I was planning to only have the extension down the side to within 50cm of the chimney
However, do you think it would be a good idea to build around the chimney so the build went a couple of meters beyond and run almost the full side of house?
Due to the drop in ground the floor would then become part concrete slab, and part suspended timber (at the far end in pic)
