Sure, been done that way for decades and will probably carry on, nevertheless it is not a fire certified method and may fail in the event of a fire.
Described? I could describe you as having six legs. It won't make it true, no matter the description. Your arguments are nonsense.It's already been described in this thread.
Your bollax about a beam twisting as much as you suggest, means it would affect ANY fixed plasterboard.You stay ignorant, you can't find a fire test proving your method works though can you? Why do you think that is?
I'm trying to understand, but I don't get it either.You still don't get it.
Eh?Timber fitted into the web of a steel beam can (when heated during a fire) twist, bow and bend at a different rate to the steel beam it was once neatly fitted to.
What a massive load of bollax.Now consider the screws holding the plasterboard against the timber, are hundreds of degrees celsius. The threads of the screws where embedded in the timber are now burning the timber, if those screws lose their grip and fail and pull out, then the plasterboard can become detached from the beam and the protection is lost.
This is a bad one from freddie. He has disappeared down the rabbit hole, that's for sure. I could understand him griping about bashed in nogg's but not bolted timber.I'm trying to understand, but I don't get it either.
This is a curious thread! Steels set in the web is completely standard construction: how is the tinber going to fail when it's bolted into the steel?I never knew that filling the void with timber bolted on was a no-no..............Its seemed to be pretty standard practice for many decades as far as I can tell
Im pretty sure Ive had it approved by S/E in the past, Ive certainly never had a BCO mention it
They haven't missed any trick...in the domestic house setting we are only concerned with premature collapse caused by fire which is what plasterboard installed in the proscribed manner delivers or even a coating of intumescent paint if exposed steels are your thing.Hmm, it seems the whole industry has missed a trick by not testing this and publishing the system as a certified method of encasing steel beams.
