- Joined
- 30 Jan 2021
- Messages
- 8
- Reaction score
- 0
- Country
Hi guys,
I recently decided to take down the wall between my kitchen and dining room. I also decided while it was down to take all the plaster off the walls (it was all blown) and take the ceiling down.
I raised a building notice and then took down the wall and installed the structural steel as per engineers specs. I had a building control visit and they said everything was fine to carry on, and to call them back after plasterboarding for final sign off.
Anyway, while the ceilings were down I decided to change from 2 ceiling roses to LED downlighters. I also moved the cooker switch to a different wall (same cable, just moved to the side).
The inspector came back for final sign off. He says everything is fine with the steel and plasterboard but won’t sign off unless I produce an electrical report for the “electrical work that has been carried out”.
I was under the impression I could change a ceiling rose to downlighters and move sockets as a DIY job. It all works perfectly and my electrician neighbour popped his head in and gave my wagobox junction box and connections in my switches and downlights the thumbs up (off the record).
Have I made a mistake here or should I be able to argue with them and get them to sign off for the structural work?
