    Dismiss Notice
Building over single skin garage - help!
Discussion in 'Building' started by gresforddragon, 26 Feb 2014.
  1. gresforddragon
    gresforddragon
    26 Feb 2014
    2
    Thanks Received:
    Clwyd
    Country:
    Hi, new on here and after some advice. I'd like to build an extra room over our single skin double garage. I realise that the walls in their current state won't be strong enough but building a second skin internally would be difficult due to all of the mains coming in through one wall and a boiler being on the wall. Are there any other options?
    I'm guessing it's either using some sort of steel structure or possibly building a second skin externally - the latter I'm guessing would be problematic.
    Limited on budget so just trying to work out options.
    Cheers
  2. Sponsored Links
  3. PrenticeBoyofDerry
    PrenticeBoyofDerry
    30 Jun 2009
    21,627
    Thanks Received:
    2,382
    Londonderry
    Country:
    You would need to employ a structural engineer to offer you advice and do the structural calculations for you.
  4. mfarrow
    mfarrow
    2 Nov 2009
    2,126
    Thanks Received:
    244
    Warwickshire
    Country:
    We have piers at the corners and steels over to make up the extra skin.
  5. trowlerman
    trowlerman
    29 Dec 2012
    124
    Thanks Received:
    8
    Oxford
    Country:
    I have done a couple of these in the past , you can build up brick piers and stick a steel on top , at joist level , you will need to check your footings depth though
  6. gresforddragon
    gresforddragon
    26 Feb 2014
    2
    Thanks Received:
    Clwyd
    Country:
    Thanks. House is built on a concrete float foundation which garage is on too, so that shouldn't be a problem.
    Is that way overly expensive compared to just building a second skin?
  7. trowlerman
    trowlerman
    29 Dec 2012
    124
    Thanks Received:
    8
    Oxford
    Country:
    no I would think cheaper ,and easier due to your services ( electric boiler )
  8. DIYnot Local
    3 Sep 2019
    Country:
  9. Sponsored Links
Loading...
Share This Page
