Building pier to support rsj
9 Aug 2019
Need to build a 230 x 230mm pier as stated in the calculations by the SE in order to support an RSJ
This will then allow me to create an opening between the garage and dining room
I'll be purchasing a wall starter kit from screwfix so I can tie into the existing brickwork
https://www.screwfix.com/p/sabrefix...MIoteG_LvA5AIVhbHtCh1NHAQdEAQYAiABEgKVAvD_BwE
Regarding the starter kit at what intervals do the fixings need to be placed onto the brickwork?
Is the wall starter kit fixed to the wall at a certain points? or at ground level to take up the first course of bricks?
Also when building the pier, I'll be using solid engineering bricks, is it best to fill the centre with mortar as i go along or after the pier is completed?
A 4:1 mix will be used to construct the pier
The pier will be approx 1.5 meters high
Cheers
Wall starters are not for piers transferring loads.
1.5m high? Do you live in The Shires?
The rest of your post makes no sense - 230 pier, fill centre, fix starter at ground level (wall within house). o_O
Apart from that, you're good to go.
The pier will be within the house, the drawing states construct 220wd x 100dp engineering brick pier
The beam is 203x102x23 UB
apologies it was a rough guess the height of the existing wall is 2.28 metres, so this will be the height of the pier
How can i tie into the existing brick work if i cannot use a wall starter?
The SE stated to use a wall starter kit
Drawing below
https://www.diynot.com/diy/media/img_20190908_105455.103258/
That engineer is an idiot. I guarantee that that pier will crack. It should be bonded in to the existing wall.
Why has he not designed it without a pier? :rolleyes:
He said there isn't sufficient space to do it without a pier as the existing rsj would be in the way and also there is not enough overhang of the existing rsj to place the new rsj above it
So wall ties in this case is not an acceptable way of tieing into the existing brickwork and placing an rsj above the pier?
He did mention toothing out the existing brickwork and integrating the new pier into it, but having looked at the brickwork he said it would be best to use a wall starter kit
If he was a proper engineer then surely he would have designed a connection to the existing beam.
Was he a real structural engineer CbuildE?
I'm not sure how he could have designed a connection if there isn't sufficient space etc also i guess it would be a lot more disruption involved
He was recommended to me by a friend, he is definitely a proper engineer. All the paperwork provided is on company headed paper.
I'm happy to build the pier but would like to know what would be the best method to tie into the existing brickwork?
My BCO was not happy with a wall tie in a similar situation, so I doubt yours will be!
So did you tooth it in to the existing wall?
I've looked at the existing wall, its a single skin brick, if i recollect correctly, this was the reason the SE advised I couldn't tooth it in, as there's not enough support
How about a bracket?
But was he a proper SE or not?
100% He is a proper SE, all on headed paper, registered company etc
The application has been approved by building control
But having sought advice here, i really don't want to be building a pier if its going to potentially crack!
Could you provide an example of how the bracket would work? and where would it be placed?
I'll be calling the SE tomorrow to discuss...
I didn't in the end, as found another way to support the beam, but the BCO wanted it toothed in
Edit, mine wasn't single skin
Although my application has been approved, I'll call the BCO tomorrow to run it past them.
The only significant load on the pier will be the bedroom wall and the rsj which it will sit on.
I just hope the SE is reasonable and carries out any adjustments/alternative solution as necessary without me having to part with more money!
Spoke to BCO explained the situation and provided images of the existing wall
BCO stated wall starter kit is fine to tie into the existing wall!
He recommended to use 2 wall ties for either leaf
I also asked whether i should use class A or B solid engineering bricks, he said either will be fine as long as they are solid :)
How have you got 2 leaves,the drawing shows 1 brick only,which is not enough. Better to build bigger pillar 330mmx215 or use steel goalpost ,and make sure foundation is acceptable.
