Building Regs and foundations....
19 Jul 2009
Leicestershire
Ok, so I know we're in a little over our depths but my husband is converting a detached double garage into a bungalow-type dwelling.
We've applied for building regs, change of use, etc. and he's an experienced labourer so we do have some knowledge (and will be using professionals where we are in doubt.
The one question we can't seem to get answered though is regarding the foundations. Could anyone let us know the required depth of foundations or prod us in the right direction for finding out?
Many thanks!
Sam
Im afraid this is not a question that can be answered without knowing the ground conditions. There is many ways of constructing foundations (pad, raft, strip) but the type to use will mainly depend on the loadings of the structure and the state of the ground.
If this is a new building you need to remember that planning permision will be needed and if it is going to be lived in, a building inspector will more than likely need to look at various stages of the construction, especially the foundations.
The best way to tackle this is to get a structural engineer to look at the plans and work out what you need, calculating loads is a very complex procedure. Doing this will aslo result in less cost if the foundations are under engineered and subsidendce occurs.
If you are converting, with no new external walls, then you don't have to touch the foundations
Otherwise assume 1m if you are in normal ground
Wish the engineers i worked with were as easy as you, how can you tell someone who obviously isnt too sure about foundations "1m". 1m what? width? depth? what about the type of concrete? Whats normal ground conditions? granular, cohesive, clay, sand?
Let me see, what was the OP's question again .... "Could anyone let us know the required depth of foundations" :roll:
I hope your engineers are more observant than you :P
touché my friend. Point still remains that you should'nt really suggest a depth of a foundation of the top of your head
Are you on summat Rob?
1m depth (min) found's is an accepted norm provided that the ground conditions satisfy simple criteria:
A. The ground is non-fertile, i.e. no dark vegetable matter.
B. The ground is firm virgin earth and is unlikely to change at depth.
What else do you need to know? :roll:
Sorry, i must of missed the detailed condition of the ground in the OP, and the 1m depth "min" out of the suggestion. Loadings not come into play with your fail safe method?
The OP obviously does not have a lot of knowledge in this area, to suggest a solution with out the details is irresponsible
If you think that the only ground conditions to look for im are the two mentioned and "1m will do" im affraid its you thats deluded. :roll:
Love is in the air
Everywhere I look around
Love is in the air
Every sight and every sound
And I don't know if I'm being foolish
Don't know if I'm being wise
But it's something that I must believe in
And it's there when I look in your eyes
Love is in the air
In the whisper of the trees
Love is in the air
In the thunder of the sea
And I don't know if I'm just dreaming
Don't know if I feel sane
And it's there when you call out my name
(Chorus)
Love is in the air
Love is in the air
Oh oh oh
Oh oh oh
Love is in the air
In the rising of the sun
Love is in the air
When the day is nearly done
And I don't know if you're an illusion
Don't know if I see it true
But you're something that I must believe in
And you're there when I reach out for you
Love is in the air
:lol:
Rob, you really need to read the thread and take it in
The OP is going through the b/regs process and is getting some info together.
They asked about foundations depth. They are not going to go out in the garden straight away and start digging after they get an answer in the thread - they want a bit of guidance/information
So, some nice guy posted "assume 1m if you are in normal ground"
Now to me, this is not a detailed specification or an instruction on how lay the foundations in the OP's locality
It sounds to me like it says "if you have normal ground then it would normally mean that foundations will be 1m deep". In turn this prompts the OP to think ... " OK, I have normal gound (my husband is a labourer so he knows what normal ground is) so I'll assume that we need to dig 1m and get the BCO to check it. I'll plan around this"
Or, the OP thinks "Hmmm, we don't seem to have normal ground, so I wonder what foundations I may need. I know, I'll post a follow-up question on www.DIYnot.com "
Jeezus, you must be hard work on site
i metre depth........ and c35 concrete.
http://www.hgtvpro.com/hpro/bp_foundation/article/0,2617,HPRO_20146_3834327,00.html[/QUOTE]
When you talk about 1 M depth, do you mean pour the concrete 1 meter deep?
No. 1m deep refers to the depth of the trench. The depth of concrete can be as little as 225mm, but many builders prefer to mass fill as this saves on brick/block laying in trenches.
yeah!
