Bulb suggestions for glass shade ceiling light
15 Dec 2008
London
Hello all. Following advice received from v helpful forum members on another post, I have installed a ceiling light which uses a bulb inside an opal glass shade (example pic below). Currently has a small 60W bulb in there which doesn’t generate enough light. Was looking at getting a varilight dimmable energy saver (20w = 100w) bulb, but at 59mm this is too wide for the opening of the shade (50mm). Because the ceiling light supposedly takes max 60w, I need something that is an energy saver. Does anyone have any suggestions for what I could use? If it helps, the dimmable aspect is not a necessity (although would be a nice feature to retain).
And on the dimmable note – if I have a dimmer switch and use a non dimmable bulb, will that work (and just not dim) or will the bulb blow – i.e. would I have to change the switch?
Lots of questions here so any help would be great!
energy savers don't like dimmers and will flash or not light at all if they are noe dimmable..
so yes you'll need to lose the dimmer..
Do a search on google for Megaman, they do all sorts of dimmerable low energy lamps
and ref
You may scrog the lamp, more probably you'll ding the dimmer.
It's not even worth a try.
and ref
Megaman look to have a good selection, will check that out in detail - thanks!
http://www.tlc-direct.co.uk/Main_Index/Lighting_Menu_Index/Lamps_and_Tubes_Index/Energy_Saving_Lamps_Index/Lamps_Energy_2a/index.html
Are 50mm wide....
http://www.tlc-direct.co.uk/Products/LALEC11BC.html
Are 43mm wide, but max is 11w non dim
http://www.tlc-direct.co.uk/Products/LAHCA42ESCL.html
Are halo dim ok but onlt 30% es rated= they are 35mm wide
Thanks for suggestions - but have brought more questions!
Re link 1 – could well work, but may be a little long for the glass shade. If the max recommended wattage is 60w for the light, will using a larger bulb (that is closer to the glass of the shade) risk getting too hot and shattering the glass? Does a 20w = 100w low energy bulb generate the same heat as a standard 20w bulb? Can I use a 70w = 100w bulb for that fitting?
And as for halogen bulbs – I thought these generated much more heat than standard bulbs?
