    Dismiss Notice
Burner Lock out (Still)
Discussion in 'Plumbing and Central Heating' started by David89, 6 Mar 2021.
  1. Terrywookfit
    Terrywookfit
    19 Jul 2007
    5,783
    Thanks Received:
    1,096
    Country:
    That should be ok at 130 psi
  2. Sponsored Links
  3. David89
    David89
    13 Feb 2021
    23
    Thanks Received:
    Country:
    Yes it's a balanced flu. Air in let fitted from motor inlet straight out the wall. Diameter same as inlet. Flu up through old chimney vertical....
  4. David89
    David89
    13 Feb 2021
    23
    Thanks Received:
    Country:
    The engineer was happy with the pump pressure.
  5. BoilerBob
    BoilerBob
    21 Feb 2020
    216
    Thanks Received:
    46
    Country:
    If the engineer can’t get the air down enough seems it’s always been high on air it may be an idea to fit an air disc. Bob
  6. David89
    David89
    13 Feb 2021
    23
    Thanks Received:
    Country:
    I have been making notes of all these suggestions and will put them to him on his next visit.
  7. Sponsored Links
  8. Terrywookfit
    Terrywookfit
    19 Jul 2007
    5,783
    Thanks Received:
    1,096
    Country:
    Or a litle more pressure
  9. oilhead
    oilhead
    29 Nov 2009
    2,179
    Thanks Received:
    523
    Shropshire
    Country:
    No echo Terry, but I'm of the opinion that if the original points aren't answered, then repeating the suggestion eventually gets to the bottom of the problem.
    We now have a nozzle size which reinforces our several suggestions of over aired start up. We now also know that the boiler has a direct air feed from outside, which I have encountered in the past where you can get a howling gale direct into the fan, (and also mice, ask me how I know) without any 'tempering ' as you get on true balanced flues, and also a draw off the conventional chimney.
    • Thanks Thanks x 1
  10. oilhead
    oilhead
    29 Nov 2009
    2,179
    Thanks Received:
    523
    Shropshire
    Country:
    I'm pretty sure the two Heating WorldsI service take an 80o Nozzle.
  11. Terrywookfit
    Terrywookfit
    19 Jul 2007
    5,783
    Thanks Received:
    1,096
    Country:
    I see very few Heating Worlds around here and avoid them if possible.
    There is one I have repaired with an electrically operated flue damper .
    I think that is HW.
  12. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
