where it has been pasteurised by heat and stored hot.
A simple cylinder does not pasteurise the water in it. A basic guide to the pasteurisation process ( power point )
www.foodafactoflife.org.uk/attachments/655ff1ea-a545-44f4fcd59aa1.ppt
Oh please do tell us more about how bacteria can grow in water stored at 60°C
If the pre-heated water is stored at temperatures between 20oC and 45oC, which favours the growth of the Legionella bacteria, and large numbers of the bacteria develop, measures may be required to prevent these bacteria causing harm to health. The technical guidance to the HSE Approved Code of Practice (L8) “The control of Legionella bacteria in water systems”, for the management of hot water systems in non-domestic premises, recommends for hot water storage cylinders that the whole contents should be heated to 60oC for one hour each day to prevent growth of Legionella bacteria in the cooler water at the bottom of the cylinder. Briefly raising the water temperature to 60oC is not considered effective.
Explain why you think a HW cylinder cannot do this
Hey Bernard , Google "de-strat pumps" (circulators)..It could if the water in the bottom of the cylinder was held at 60°C for the necessary time ( WRAS recommend one hour for domestic pre-heated water ).
Any hot water taken from the cylinder will be replaced by cold water most often fed in at or near the base of the cylinder. This will take that area of the cylinder below 60°C and maybe into the breeding temperature for bacteria.
Batch pasteurising requires the batch to be held as a batch for the duration. Stirring of the liquid to reduce thermal stratification is used in a lot of batch processing.
That one reason is that un-vented cylinders do not require a header tank and thus the risk of animals / rodents drowning in that tank does not exist with an un-vented cylinder.
Google not necessary, have experience of control systems for them.Hey Bernard , Google "de-strat pumps" (circulators)..
It could be an issue if taps fed from the CWSC ( cold water storage cistern ) were considered as supplying drinking water. One reason CWSC are ( should be ) thermally insulated is to prevent the temperature of the stored water rising to far. Is there amy tmeperature control ( insulation ) on accumulators used to "supplement" low flow rate mains supplies ( a CWSC is in effect a large capacity accumulator but at lower operating pressure )...would it be an issue bearing in mind cold water outlets are also fed from these CWSC's??
Potable water everywhere, silent operation, reduced pipework, better hot water performance etc are all benefits, amongst a few others you've been told several times
