    Dismiss Notice
Butt (UY) Connectors In Alarm
Discussion in 'Alarms, CCTV & Telephones' started by Stuart Frost, 18 Dec 2020.
  1. Stuart Frost
    Stuart Frost
    14 Apr 2019
    36
    Thanks Received:
    2
    Country:
    Hi. I am replacing a Veritas alarm which has 8 wired zones with an Elite 64W and 8XP expander. The alarm is situated in a very cramped area so I am concerned about transferring the wires successfully.
    What I was thinking was could I prewire the panel and expander with a short piece of wire on each terminal and then use a butt UY connector (I have the gel type ones that just need pliers to use) to join each existing wire or would that be a bad idea?
    Stu
  2. Sponsored Links
  3. Handymanjo
    Handymanjo
    2 Feb 2016
    1,933
    Thanks Received:
    373
    Newark
    Country:
    Would not recommend that. Too many joints to check if problems with cabling.
  4. sparkymarka
    sparkymarka
    16 Feb 2011
    8,904
    Thanks Received:
    1,351
    Sheffield
    Country:
    Take the wires out one by one and wire them into the 8xp .....then you only have to connect it to the panel with the network !
  5. Stuart Frost
    Stuart Frost
    14 Apr 2019
    36
    Thanks Received:
    2
    Country:
    That’s what I was going to do but as I mentioned, the existing alarm is in a very cramped area so my concern is getting the wires in so that they stay put while I tighten the screws. That’s why I was considering the easier way of just sticking the wires into the connector and a quick squeeze of the pliers.
  6. Stuart Frost
    Stuart Frost
    14 Apr 2019
    36
    Thanks Received:
    2
    Country:
    Just seen bootlace ferrules which I never knew existed. Are these recommended for use in alarms as I think they would make getting the wires to stay in whilst tightening the screws a great help.
  7. Handymanjo
    Handymanjo
    2 Feb 2016
    1,933
    Thanks Received:
    373
    Newark
    Country:
    Same issue, if not crimped correctly could lead to cabling issues.
    I would wire directly into terminals of expander. May be difficult due to access as you said ,but would save a lot of hassle if joints are not correct. Just take your time and have plenty of light when wiring up.
    • Like Like x 2
    • Thanks Thanks x 1
  8. DIYnot Local
    3 Sep 2019
    Country:
  9. Sponsored Links
Loading...
Share This Page
