I don't know how (or if) the calculation for residual head is done to give the proper pump speed/output but quite easy to calculate the pump head from a known speed. For example if the pump speed is 46.3% then the pump head (at the pump) is 700×0.463^2, 150mb and the residual head will be a little less, it will be nowhere near the 400mb ABV set pressure. You might take a full set of readings at your present 150mb setting, then increase it to 200mb and take another full set of readings exactly like the ones you took in post #101, would expect a pump speed similar to what you got of 57% = 227mb based on a 7M pump or a max of 260mb if the circ pump is 8M, both far away from the ABV setting of 0.4.
