Is it correct you can not mix old and new cable colours.does it meam you can not mix colours in sockets and light switches.can one use old colour cable to make a new complete ring circuit but old and new colours would mix in consumer unit.please help.
On a new installation the new colour code must be used,but in an existing installation wired in the old colours you may use the new colour cable to make alterations and additions.
A warning label must be afixed to the consumers unit saying that the installation uses colour codes to two versions of BS7671 ( 16th ed regs ) its also a good idea to use the labels on any joint boxes with mixed cables.
See appendix 7 of BS7671, basically you can use colours to two versions providing you post a notice at the consumer unit warning this. In a single phase system the interface doesn't need to be marked.
