- Joined
- 9 Jan 2005
- Messages
- 41
- Reaction score
- 0
- Country
I have a double oven rated at 5kw and a ceramic hob at 5.8kw. I intended to run a 6mm cable from a 32A MCB to a CCU. From this CCU a 6mm cable to the oven. Then a 6mm cable from the oven, along the wall behind the base units (just below worktop) to another CCU in an adjacent cupboard to the hob (about 5 metres away) then a 6mm cable from this CCU to the hob.
Is this acceptable on the following counts:
1. The cable size
2. The breaker size
3. The cable route (under worktops)
Your help is gratefully received, as always. Great forum!
1. The cable size
2. The breaker size
