- Joined
- 21 Mar 2024
- Messages
- 573
- Reaction score
- 164
- Country
Just me?Never assume.
I'm saying I don't know how it will behave and those calculations are meaningless.Are you saying the current will rise with lower voltage?
You probably need to tell that to the marketing people who seem to have almost universally decided that they want the power of their products quoted into relation to 240V, which makes the products sound more powerful than they actually are when supplied with the "European Standard" 230VI'd be more likely to assume it's given for 230V, that's the european standard.
If you look for it, documentation will (should) nearly always tell you what voltage the claimed power relates to - and if you have that information, the calculations are correct, not 'meaningless'.I'm saying I don't know how it will behave and those calculations are meaningless.
I thought it was fairly obvious I was talking about the ohms law transpositionIf you look for it, documentation will (should) nearly always tell you what voltage the claimed power relates to - and if you have that information, the calculations are correct, not 'meaningless'.
No, that wasn't 'obvious' (at least, not to me) - so are you saying that you don't believe that an electric cooker (at least, traditional oven, gill and hotplate elements) behaves as a resistive load?I thought it was fairly obvious I was talking about the ohms law transposition
That's because you've not bothered to read any of the prior posts in this thread.No, that wasn't 'obvious' (at least, not to me)
My first postTo sum up, I will be having installed a full Boscfh Kitchen set up:
Oven 2.4Kw
Oven (with microwave 2.8Kw
Induction Hob 7.4Kw
Warming Drawer appraently up to 600Watt (cannot find appliance specific wattage)
Extractor Fan 233 Watt
Either way, induction hobs are far from a purely resistive load (it's in the name) so you can't assume the current drops with the voltage.
I certainly did 'bother' but, as you point out, I'd forgotten what you had written, for which I apologise.That's because you've not bothered to read any of the prior posts in this thread.
As I've said, that will very rarely the case, thanks to the marketeers.My first post
Fair enough - again, I'd forgotten that we were talking about an induction hob. However, since we are, and as you are suggesting, one cannot assume that the current (to the induction hob) will be less at 230V than at 240V. In fact, it may well be higher. So, again, I ow you an apology.Either way, induction hobs are far from a purely resistive load (it's in the name) so you can't assume the current drops with the voltage.
Indeed - at least, one can't undertake calculations based on such a (probably incorrect) assumption if/when one remembers that one is talking about an induction hob (or anything else else which is 'probably non-resistive')@JohnW2 No worries - agreed it's not a major issue I just thought it's worth pointing out that you can't make calculations based on a resistive circuit
As was discussed on here a while back, with an electric motor (normal induction type) with varying voltage the power stays very nearly constant so the current varies inverselyIndeed - at least, one can't undertake calculations based on such a (probably incorrect) assumption if/when one remembers that one is talking about an induction hob (or anything else else which is 'probably non-resistive')![]()
True - although I don't think many people would accuse a motor of being a 'resistive load'As was discussed on here a while back, with an electric motor (normal induction type) with varying voltage the power stays very nearly constant so the current varies inversely
Thinking about it a bit more - with a pure inductance (or capacitance) the impedance is constant at a given frequency, so the current varies directly with voltage. I'd guess that applies to an induction hob but not 100% sure.True - although I don't think many people would accuse a motor of being a 'resistive load'However, I would have thought more important, domestically, is the fact that the same is generally true of any of the countless things which use SMPSUs.
That would be true for a purely reactive load, but such a load would presumably not consume any power!Thinking about it a bit more - with a pure inductance (or capacitance) the impedance is constant at a given frequency, so the current varies directly with voltage. I'd guess that applies to an induction hob but not 100% sure.
