Indeed so - I never suggested otherwise.Like induction hobs, I believe?
A lot of my colleagues, gasmen, refuse to allow the concessions allowed in the REGS,
I imagine they also refuse to take any notice of what non-gasmen say about what should or should not be done wrt gas installation work.
They should be treated the same when pontificating about areas outside their expertise.
Good point, and plugwash's comment.That would be true for a purely reactive load, but such a load would presumably not consume any power!
That is certainly my understanding - overall, an induction hob (downstream of the controlling electronics) will therefore presumably look largely as a resistive load.Good point, and plugwash's comment.
Am I right thinking the induction hob works by creating eddy currents in the pan, hence resistive heating?
Although, as above, the hob 'in itself' will probably appear as a largely resistive load, the voltage/current relationship in terms of the mains power supply will, as discussed, presumably depend crucially, and almost totally, on what the electronics chooses to do (not the least in terms of 'current limiting') ?It would be interesting to know how the current varies with voltage
And that excuses them from charging pnters for work that is not neccessary?
I take it from yur commnt that you have a problem with a Gasman asking about electrics, or maybe you have a problem wih me asking for confirmation that I do or do not need a new CU plus 3 seperate radials to a kitchen, and that i should just take his quote as a neccessary evil?
Isn't the name "induction hob" a bit of a give-away that it uses inductors, and therefore isn't a resistive device?That is certainly my understanding - overall, an induction hob (downstream of the controlling electronics) will therefore presumably look largely as a resistive load.
He insists that there is no DF on an induction hob, and it will need 10mm. He showed me someinternet searches to support that, but am struggling to find them now.
That rather depends on what you mean.Isn't the name "induction hob" a bit of a give-away that it uses inductors, and therefore isn't a resistive device?
Quite so. One can't defy the Laws of Physics. The concept of diversity could only be less applicable to induction hobs than to 'traditional' ones if they were less efficient in heating the contents of the pans - which is probably the opposite of the truth.If diversity is OK for halogen or traditional hobs because they cycle on and off, don't run flat out all the time, then it's OK for induction hobs for exactly the same reasons.
I assume , though, that you are referencing me?How do gasmen come to be charging customers for electrical work?
What bizarre suggestions.
My comment was to say that people should take as much notice of gasmen pontificating about how electrical work should be done as gasmen would take of electricians, or joiners, or etc pontificating about how gas work should be done.
I would love to check against the instructions- but it seems difficult to get INSTALLATION instructions before selecting an appliance. In fact, I know what we want, model wise, but cannot get the details ahead of purchase.@FiremanT My mum's got a 7.4kw induction hob running off a 13amp plug top (not right but it's not popped yet). Run a cable suitable for a 32amp breaker and you'll be absolutely fine - it is worth checking the manufacturer's instructions though in case they specify lower overload protection for the oven - being an element though it shouldn't need it.
Another?I have spoken to anther qualifed sparks, a colleague.
Clearly nonsense on both parts.He insists that there is no DF on an induction hob, and it will need 10mm.
