I'm wondering if any one has any advice. Basically I am wiring my new build house for TV and Satellite (CAT6A and Coax cable) and have successfully gained access from a downstairs cupboard to the second floor (just under a metal stud partition) and from the loft to the second floor (down in the same metal stud partition).
However the problem I face is that it seems as through the metal stud partition does not meet the floor as when I look under the floor board there is no entry to the above wall and looking in the stud wall it seems to finish about 2 inches from the floor (just above the skirting).
Therefore I have about 2 inches of blockage between getting the cables accessed
My only thoughts at the moment is try using a flexible drill shaft to drill up into the wall and hopefully through to the stud wall (can this be done) or just use ducting to come out from the wall and into the floor (I hate this idea).
Cheers for any advice,
Gary
Gary
