Hi everyone, I was going to change pads on my focus 2004 and when I unbolted the bottom guide pin of the caliper it felt like it was loose.
Once the caliper was out of the way I tried the bolt and in fact, it just turned around endlessly.
It's the actual mounting hole that's stripped, the bolt is ok.
Looking for a solution I saw on other forums people recommending helicoil or a repair kit like this one
Or, I was thinking of a guide pin of same size but with an M10 thread instead of M9 and tap the hole to that size (can I keep it dead straight?)
What do you think is the best solution?
Changing the whole hub is out of the question, it would mean scrap the car.
16PC Brake Caliper Thread Repair Kit M9 X 1.25mm with Alignment Guides | 3512 | eBay UK
Description 16pc Brake Calliper Guide Thread Repair Kit with Titanium coated core drill Tap and 10 threaded inserts. Applicable to Volkswagen - Golf MKIV / Beetle Seat - Exeo Estate ST 170 Ford - Focus | C-Max Vauxhall - Astra-G
www.ebay.co.uk
