A dish washer does not use much power except when heating water and on a staggered start so both not heating together likely there would not be a problem.
A spur is rated at about 20A which is of course larger than the single 13A fuse but not double and I would not want to run two 13A appliances myself from a spur.
But we at this stage don't know they are 13A a washing machine I just looked at was Max 2200W which is just over 19A for two so would be just within the limits.
So I would say two 2.2KW machines OK but two 3Kw machines no.
