I reside in the republic of Ireland (where plugs and sockets are the same as in the UK), and I just bought a portable electric generator online from the Netherlands. Unfortunately, now that it has arrived, it turns out that the two electric sockets on the generator are Schuko sockets (each 220v, 16A), thus posing a compatibilty problem with the plugs we have in Ireland.
Btw, my problem is similar to the one in the OP of the following old but very informative thread, except that mine is essentially the reverse problem.
https://www.diynot.com/diy/threads/can-schuko-plugs-be-wired-to-uk-bought-electrical-items.138102
The generator I bought is a 'Champion 3500 Watt LPG Dual Fuel Inverter Generator'.
The full range of Champion inverter generators is listed at this webpage:
https://www.championpowerequipment.co.uk/browse/products/Champion-Inverter-Generators.
But there are two versions of this 3500 Watt generator listed.
The high-level specs didn't mention anything about differing sockets, so I wrongly assumed the reason for the two distinct model nos. had something to do with the UK having left the EU e.g. maybe for tracking whether or not import tax was due).This was very poorly marketed because there are 3 EU countries that use the UK-style sockets: Ireland, Malta and Cyprus.
As a workaround, I'm thinking of using an extention lead and simply changing the plug on the lead from the UK-style plug to a Schuko plug, while maintaining the sockets at the other end of the lead as UK-style sockets.
My intention with the generator is to be able to power one or maybe two devices at a time by directly connecting the devices to the generator in case of a power cut e.g. radio, washing machine.
Having read through the older thread mentioned above, I don't think there should be an issue regarding polarity (since alternating current flows back and forth between the two directions anyway) and so either of the Line or Neutral wires on the extention lead could be connected to either of the two Line pins on the Schuko socket. Of course, the Neutral of each socket on the extention lead will likely now have high voltage on it. But as pointed out in the older thread, Neutral should always be treated as if it had high voltage anyway.
Is there anything I'm missing here or am I okay to go ahead with this fix?
- The first version has model no. 73001i-DF and has a UK flag next to it.
- The second version has model no. 73001i-DF-EU and has an EU flag next to it.
