I have a heating system with 2 zone valves, one for hot water cylinder and one for the radiators.
I would like to add a 3rd zone valve (controlled by a separate time control switch) for a heated towel radiator in the bathroom so in the summer months it can be heated to dry the towels.
I have a solar thermal hot water panel which heats the hot water tank in the summer so the boiler rarely fires up in the summer to heat the water cylinder.
I was planning on using the separate time switch to operate the 3rd zone valve at 9.30pm each night for 30 minutes to warm the towel radiator.
During the colder months the central heating would come on during the day/evening and this late 30 minute boost would not be required. I could then manually cancel the 9.30pm boost as the towel rail would already have been heated.
Is it possible for the towel rail 3rd zone valve to be operated by the heating zone valve i.e. when the heating comes on it automatically operates the towel radiator zone valve so that water can flow through both circuits?
Thanks for any replies.
