Your plan drawer has been lazy and has not scaled his hatches, hence they are too tightly drawn.Thanks gents, I should explain this is from an architectural plan for an extension. Ive never seen it before. If it doesn't represent a material is it possible it's just there to look pretty? I know it's not brick or block and I can't find timber on Google.
Legend? Not since 1975 (or leaving drawing school) which ever was last.There should be a legend on the drawing ( or in the drawing pack ) describing what each pattern of hatching represents,
One is supposed to be brick (although its a wrong hatch for brick), and the other darker one seems to be too - but whether that's supposed to represent new work or is just an even tighter hatch, who knows![]()
For what purpose did you ask him to draw them in the first place?
If he has not drawn them to your requirements, or for the purpose you instructed him, then he needs to change them - and at no cost.
Seems like you hired an idiot.
But if the drawings were just for planning, then that implies that there will be more work and extra cost for drawings for building regs. If you agreed a cost for both, then that's a different matter.
The choice seems to be either you insist on they are rectified at no cost, and completed to an acceptable and accurate standard, or you kick him up the arse and find someone competent.
