Can anyone recommend me a reusable face mask system?
4 Dec 2003
I've been using disposable face masks whilst using power tools and they are OK but seem to work out expensive and I find that my safety goggles steam up annoyingly. Anyone able to recommend something better? I need the masks to be OK for use whilst cutting wood with routers/drills/saws and for sanding /drilling plaster and brickwork.
Cheers
JD
I'm guessing from your handle that this is DIY use?
If so, then probably no, I can't recommend one - most of the re-usables have cartridges with a shelf-life, and a use-by period once you open them. Unless you're using them all the time, frankly I don't think they work out cheaper. For professional use, YMMV. You would also need records of filter changes etc to ensure that the use is compliant, if you are using this sort of PPE for your job.
As for steaming up glasses / goggles, I've been using the blasted things for the best part of twenty years, and I've yet to find one that doesn't do this to some extent. I generally use 3M 8810's, which are as good as anything I've tried, but even an air-fed doesn't entirely overcome the problem.
Bear in mind that if you are using PPE like this as part of your job (i.e. it is noted in the risk assessment), then it now needs to be checked for fit (really!).
M
i use them en149 pp2 masks, no particuliar make so long as it has the 149 standard, and bottom line is , how much are a pair of lungs.....
anyway i have found the above mask combined with this ,folk think theyve got a reeet posh twit.
:LOL:
