Observing a friend house being rewired I noticed something that makes me raise the subject question.
The cable in question os part of the central heating control wiring. The wiring centre will be fed from a Fused Connection Unit with a fuse of the correct rating for the cables/flex's on the circuit. From the wiring centre there will be the usual flex's to motorised valves etc., all conveiniently located within a metre of the wiring centre. All normal so far. But the wiring to the programmable thermostat (2 channel device) which has to take a more convoluted route has been first fixed using a 5 core flex. Because that part of the wiring is fixed I would have thought use of cable would be better, perhaps two twin and earth cables running alongside each other.
The 5 core flex will no doubt be buried in a hall wall plaster where is drops from ceiling level to the thermostat. It will have mechanical protection as used for buried cable. But is it permissable to bury flex ?
So far I have some concerns about the electrician employed as he had installed a first floor ring main cable using some holes knocked through walls (in the floor space) by the central heating installer. That in itself was not a problem but having the 2.5mm T&E curled around (in contact with) the 22mm copper heating pipes was not acceptable!
