    Dismiss Notice
Can I connect 90° Space Saver Bend in HORIZONTAL position?
Discussion in 'Plumbing and Central Heating' started by zappastix, 13 Mar 2011.
  1. zappastix
    zappastix
    2 Oct 2007
    219
    Thanks Received:
    2
    Sussex
    Country:
    :?: Hi
    I need to connect the spigot on new toilet to soil pipe.
    My problem is that a regular 90° pan connector leaves a gap
    between 40-50mm (to far forward from the wall).
    Burnerman (from this site), kindly suggested using a 90° Space Saver Bend.
    While looking to buy one I read: to be used in a VERTICAL position.
    Is this correct?
    I can't see why it cannot be HORIZONTAL.
    Could you please confirm if a 90° Space Saver Bend is OK to fit in a
    horizontal position - if it has to be vertical, do you know the reason why.
    I really don't want to fit something that might cause a problem.
    Many thanks.
  2. Sponsored Links
  3. seco services
    seco services
    3 Dec 2007
    15,701
    Thanks Received:
    1,260
    Essex
    Country:
    have read before about only fitting them vertical.
    try one if your close to the main stack can't really see an issue with the flow as would be on a long run.
    • Thanks Thanks x 1
  4. zappastix
    zappastix
    2 Oct 2007
    219
    Thanks Received:
    2
    Sussex
    Country:
    Thanks seco services.
    The run is only around 2 meters (WC is on ground floor).
    I'll take a chance.
  5. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
