I need to connect the spigot on new toilet to soil pipe.
My problem is that a regular 90° pan connector leaves a gap
between 40-50mm (to far forward from the wall).
Burnerman (from this site), kindly suggested using a 90° Space Saver Bend.
While looking to buy one I read: to be used in a VERTICAL position.
Is this correct?
I can't see why it cannot be HORIZONTAL.
Could you please confirm if a 90° Space Saver Bend is OK to fit in a
horizontal position - if it has to be vertical, do you know the reason why.
I really don't want to fit something that might cause a problem.
Many thanks.
