Can I fit 3-wire to my light switch
18 Jul 2021
Hi, I've recnetly bought some smart switches that requires 3-wire connection. I've opened my old switch and found there are dangling blue and black wires. I wonder are these just un-used neutral wire as the old switch is 2 wire?
Well, the blues and blacks are not unused neutrals. They either are neutrals or they are not.
It's a rather unusual arrangement.
You will have to test whether they are connected to neutral.
If they are, then you can connect your new switches to them.
Agreed other than I see nothing unusual.
I have a question. The top image is for 3 light/3 switches, and I only have 3 neutral wires, and the bottom is for 2 light and I only have 2 wires.
I was expecting to have 4 neutral wires (3 from light 1 from the power supply) for 3 lights. Am I incorrect?
You are not incorrect.
You have a three-core (red, yellow & blue) and earth going to two of the lights, so only one neutral.
Therefore - there must be a (switched) live and neutral running between these two lights - or some other arrangement with a junction box somewhere.
Not unheard of, but that is why I said it was unusual (i.e. not usual).
EFLI. Running a 3 core to a switch, using one core for neutral is not unusual. It happens every day. No matter what you say. You'll find it happens all the time.
I was being light-hearted following on the ‘not unusual’ theme. Forgot this is a serious site for serious people. I posted the first three lines of the second verse in the song.
Being serious, seeing a 3-core in a 3-plate installation is becoming more common as more people are fitting home automation and wireless light switching.
