can I fitter a dimmer switch in these circumstances
18 Mar 2008
Belfast
I am changing the switch/socket plates in the kitchen as I am renovating the room. There are no queries about the sockets - just the one light switch I have in there.
That switch is a 2 gang switch operating both the kitchen and dining room. In the kitchen are 6 spotlights and in the dining room a spotlight bar with 4 spotlights. they are fitted and operating of the normal 2 gangway switch plate.
Can I change the standard 2 way to a 2 way dimmer?. The reason I ask as I am not sure whether dimmers can be used with spotlights/spotlight bars
many thanks for your help
P.S below is the the style of switch I am buying and this is the dimmer I would fit if it would work
http://www.screwfix.com/prods/94503...ofile/Crabtree-2G-2W-250W-Dimmer-Black-Nickel
You need to be careful with dimmers because they are only rated to carry a certain load, normally 2 gang units a 250W per gang. You say you have 6 lights in your kitchen, assuming they are 50W then that is 300W and a few other factors like are they 12V or 230V spots etc to consider
Reading the lights it says on both bar and individual that they are Max 50W GU10.....sorry all I know....if that helps
and reading the leaflet that came with it says max bulb type 50W GU10 Mains 230-240V self shielded halogen bulb....so I have 6 spots in kitchen and 4 on the bar
The dimmer will not be able to handle 6 lamps @ 50W each. One option would be to change the 50W lamps in the kitchen to 40W energy saving halogens (give roughly the same light output as standard 50W lamps). That gives you 240W total, rather than the 300W, which is under the 250W limit of the dimmer you have chosen.
http://www.litebulbs.co.uk/category/156/osram-gu10-energy-saving-halogen-light-bulbs.aspx
The risk with putting lower wattage lamps in is that somebody could replace the 40W lamps with 50W lamps without knowing the limits of the dimmer and it could fail.
Very helpful and clear. Appreciate your time - many thanks
Some companies will do a 400VA 2 gang dimmer. I think Scolmore do it in their Click range. If you fit a dimmer make sure your GU10 lamps are a good quality fused variety. Most name brands make fused lamps (Osram, Sylvania, Phillips etc) and will ensure that when they blow they won't damage your dimmer. Also ensure that the dimmer you choose doesn't have to be 'de rated'. Some of the cheaper dimmers will only be able to dim half the wattage that it claims when used with GU10 lamps.
So you end up with a dimmer, glimmer :lol:
It always amuses me that folk put in a powerful, inefficient form of lighting and then decide they need to reduce the output.
Surely its better to select the light level you require and get a lamp to suit.
IMHO halogen lights are about the most unsuitable lighting for a work area, such as a kitchen.
PS, I'm having a grumpy day, I hope it doesn't show!! :evil:
