can i float a solid osk floor over kingspan insulation
8 Feb 2009
Norfolk
hi, I am currently finishing my extension and the wife has picked a very expensive hand scraped solid oak floor (120mm boards), I deliberately left the concrete slab 100mm low to allow for insulation and then a floating floor but everywhere seems to suggest nailing the new floor.
Can i glue and float over the insulation or do i need to batten out the floor.
Any help would be much appreciated
Can you give us a bit more information on the measurements of your Oak floor?
Thickness, length and - if you know - with random length floors how many (percentage) of your boards are short (short meaning 1/4 of the average length?)
In most cases you can install 120mm wide boards floating but can only say definite if you answer the above questions
many thanks WoodYouLike for your response the measurements are as follows
room size 6.5 m X 3.9 m split into 2 via a supporting nib each side (600mm x 200mm)
I will be using one of the following
wood size 130mm X 18mm X 0.3M - 1.5M lengths this is from next flooring online type NATURA HAND DISTRESSED GOLDEN OAK
wood size 120mm X 18mm x 0.3M - 1.5M lengths this is from my local timber merchant and I do not have a brand or type but it is hand scraped
If either of these are ok could you please recommend a good glue also would the floor look better laid longways or shortways
Regards
Howard
First impression I would say install longways continues, as long as there is no narrow entrance between the two areas. If there is, install a divider in the 'doorway' and treat every area as separate room.
As for installation method: do you know how many of the boards are the shortest? If there are more than 15 % 'short' lenghts (1/4 of the longest length = 375mm) your best bet is to glue it down with flexible adhesive like Basicoll PU-650SE.
If you have a standard mix of less than 15% short you could install the boards floating on combi-underlayment (with DPM in it)
