Hi Folks,
As above... would it be acceptable to Building Control to join two lengths of 200mm x 50mm C16 floor joists to make one joist?
I had intended converting a 5m x 3m area of the loft but I have now decided to run a wall plate around the entire loft; this will require a 4.3m joist to span between the front and back elevation.
This means that the timbers I have are too small hence the above question.
Any advice or comments will be gratefully received.
Regards,
Will.
Regards,
Will.
