I have cut in the ceiling and walls of a room which I thought wouldnt take long but ended up taking 2-3 hours longer than anticipated. It got way too late to start rollering so was wondering whether I would be ok by rollering a day after?
You may get a slight difference in finish - much more likely with a silk, but matt should be OK.
General routine is cut in the ceiling then paint, then cut in each wall individually and paint them. A lot depends on the paint so its not a hard and fast rule, just see what the first coat comes out like and adjust method accordingly.
the problem was, the walls and ceilings are so long that by the time i finished from one end to the other, the cutting in lines would dry completely anyway
