Yes, if you have the correctly rated cable for the current drawn by the lights( both new & exsisting ) & the correct size fuse in the plug, then you can do as you ask. You need to supply lamp ratings & current cable size, plus run length to the new lamp, for any further advice.
The new light is 150W and i think the other is 500W
Pretty sure ive got 3 core flex 1.5mm x 10 metres long
And the plug has a 13amp fuse
Reading the instructions it recommends using a 5amp fuse in the new light
Both lamps are 150w just found the instructions for the lamp thats up.
So even though it will be powering 2 lamps is it still a 5amp fuse?
What's the result of 300 / 230?
