can i run 4 spare sokets in to my shed from a main soket
7 Sep 2012
Liverpool
I have a shed next to my house can I run 4spare sokets from it if not how can I do it the cheapest way without ripping my plasterboards of to rewire the new 4 sokets
The subject of your message was " can i run 4 spare sokets in to my shed from a main soket", but now you're asking "can I run 4spare sokets from it".
Which is it?
Built on to it, or is there a gap?
main soket
What do you mean by that?
You can't spur 4 sockets directly from one on a ring final, only 1. Or none if the socket is already a spur. You can run 4 from a fused spur if it would be OK for your use of them to be limited to 13A in total. But you can't even add a fused spur to an existing unfused one, you'd have to convert it.
Is the donor socket on a ring?
Is it a spur?
Is the circuit a radial?
Unless it's a radial, extending the circuit would be better.
Is the circuit RCD protected?
Is this going to be the first time electricity is taken into the shed, and if so what type of supply do you have ( http://www.diynot.com/wiki/electrics:earthing-arrangements ) and are there any extraneous-conductive-parts in the shed?
You might have to make a decision regarding exporting a TN-C-S/PME earth. http://electrical.theiet.org/wiring-matters/16/elect-inst-outdoors.cfm?type=pdf
Also, how do you plan to test your new wiring and sockets for continuity, insulation resistance and fault loop impedance?
Do you understand how the way in which you install cables affects how much current they can carry?
Do you know the rules concerning cables concealed in walls, partitions and under floors?
Do you know the rules for cables run outdoors, buried in the ground or overhead?
If you're joining cables, how should this be done / not be done and in what circumstances are different methods acceptable?
I call it a shed but its my office, the thing is there is a 10ft gap between me and my next door neighbour so I have built a a big room between the 2 houses I have broght a spar out running of my hall way soket and at the othe end I have brought another soket from my kitchen so one one end I have ran 4 spar twin sockets and the other side the same how do I make it safe without rewiren the whole lot coz of plasterboards
You need an electrician.
And don't use any of the sockets until he's sorted them out.
Did you get the necessary planning permission and Building Regulations approval for this "room"?
