Hi, I need to cut a 10mm wide channel in a few fire doors to fit smoke and heat seals.
Ive been struggling to find a router under £50, which is a bit much, Ive got an old circular saw, I was wondering if I can get a good result by running it up and down a few times.
I guess the channel has to be quite flat as the seals are self adhesive.
Failing that is there a way of using a drill with a router bit ?
Alternatively I can get seals that dont need routing, cost around £39, Im a bit skeptical tyat they will stay on though.
thanks
thanks
