    Dismiss Notice
Can oil bleed into a blue plastic water pipe?
Discussion in 'Plumbing and Central Heating' started by roy c, 6 Jul 2017.
  1. roy c
    roy c
    19 Jan 2008
    2,373
    Thanks Received:
    423
    Country:
    I have a blue poly water pipe that runs along side of my oil pipe to the boiler..There seems to be an oily smell when we run the cold tap. So as anyone heard of oil bleeding into blue poly?
  2. Sponsored Links
  3. Ian H
    Ian H
    14 Sep 2010
    7,037
    Thanks Received:
    859
    Rochdale
    Country:
    Yes, there is a type of pipe called 'ProtectorLine' that's MDPE with an extra layer of metal under a second layer of MDPE.
    I might have a bit in the van to show you, definitely have a roll in the yard.
  4. Ian H
    Ian H
    14 Sep 2010
    7,037
    Thanks Received:
    859
    Rochdale
    Country:
  5. roy c
    roy c
    19 Jan 2008
    2,373
    Thanks Received:
    423
    Country:
    So the oil does bleed thru the poly? I forgot to say that the oil pipe and poly pipe are in a "sleeve" and there is fuel oil lying in the sleeve.. The distance from the oil tank to the boiler must be about 18 metres...
  6. Ian H
    Ian H
    14 Sep 2010
    7,037
    Thanks Received:
    859
    Rochdale
    Country:
    Apparently it does. I've only ever come across it once at a house that was built in the site of an old petrol station.
    Their Lead supply burst and we had to relay it with ProtectorLine because of the contamination risk.
  7. Sponsored Links
  8. Elkato531
    Elkato531
    22 Jul 2009
    1,091
    Thanks Received:
    277
    Sussex
    Country:
    You also need to be checking why there is fuel oil in the sleeve. If it due to a leak it needs sorting.
  9. roy c
    roy c
    19 Jan 2008
    2,373
    Thanks Received:
    423
    Country:
    Yes I know that, it's the bleeding through that I am worried about...
  10. dilalio
    dilalio
    20 Mar 2009
    7,937
    Thanks Received:
    1,293
    Potters Bar
    Country:
    Fuel and potable in the same conduit! :eek:
    New separate moling for the two methinks.
  11. roy c
    roy c
    19 Jan 2008
    2,373
    Thanks Received:
    423
    Country:
    Yes that what I thought. The two pipes were put in together 20 years ago! So I will reroute new pipe for oil and water and keep them separate. Thanks for all your input..
  12. dilalio
    dilalio
    20 Mar 2009
    7,937
    Thanks Received:
    1,293
    Potters Bar
    Country:
    (y) You know it makes sense ;)
  13. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
