I have a blue poly water pipe that runs along side of my oil pipe to the boiler..There seems to be an oily smell when we run the cold tap. So as anyone heard of oil bleeding into blue poly?
So the oil does bleed thru the poly? I forgot to say that the oil pipe and poly pipe are in a "sleeve" and there is fuel oil lying in the sleeve.. The distance from the oil tank to the boiler must be about 18 metres...
Yes that what I thought. The two pipes were put in together 20 years ago! So I will reroute new pipe for oil and water and keep them separate. Thanks for all your input..
