Can RSJ beams be placed on top of each other
10 Feb 2021
I have recently had RSJ's installed to prop up chimney stacks as the chimney breasts underneath were removed. The BC were informed and a structural engineer engaged. I provided the calculation and plans to the builder. I noticed that the fabricator had predrilled holes in the beams supplied . But the builder that I got to help install these did not use the predrilled holes and instead placed the beams on top of each other . Is this acceptable or would Building control flag this up. I have attached pictures and the plan from the SE. Thanks
  • Beams.pdf
  • Beam Layout.pdf
Usual practice is to connect an incoming beam to the web of the supporting beam by bolting through a welded end-plate or suchlike.
But this involves extra costs in fabrication, and in domestic settings with relatively low loads, what your builder has done is perfectly acceptable.
As Tony says, no problem. The only thing I might have done is add a couple of tab bolts (M8s or something) through the flanges. But there's practically no load on it, so not critical.
