    Dismiss Notice
Can someone explain the German 5 wire 230V system please?
Discussion in 'Electrics Outside of the UK' started by Geedon, 1 Oct 2007.
  1. Geedon
    Geedon
    1 Oct 2007
    2
    Thanks Received:
    Country:
    Hello all and a bit new to this - but - we have a house in Germany and the wiring there seems complex with 440 230 etc.
    Most grateful for either direct explaination or hyperlink to an explaination of how the 5 wire 230v system works please?
    Many thanks ....
  2. Sponsored Links
  3. plugwash
    plugwash
    28 Mar 2004
    9,195
    Thanks Received:
    314
    Country:
    I would guess you mean a 230/400 three phase system.
    carefully meausre the voltages with a multimeter, if you get about 400 between any two live wires and about 230 between any live wire and neutral you have a 230/400 three phase system.
    be very carefull, 400V is far nastier than 230V
  4. Geedon
    Geedon
    1 Oct 2007
    2
    Thanks Received:
    Country:
    :idea: Many thanks - yhink I'll get a local sparky to the job!!
  5. briwire
    briwire
    18 Aug 2007
    258
    Thanks Received:
    3
    Cheshire
    Country:
    Is it a big house. Usually 3 phase supplies are limited to larger installations or those with many motors.
  6. plugwash
    plugwash
    28 Mar 2004
    9,195
    Thanks Received:
    314
    Country:
    While that is the case in the UK it is not the same everywhere. Small three phase installations seem quite common in parts of continental europe especially on older installations.
  7. Sponsored Links
  8. bernardgreen
    bernardgreen
    3 Nov 2006
    23,783
    Thanks Received:
    2,294
    Bedfordshire
    Country:
    In 1972 electric showers in Germany were more often than not 3 phase as were ovens cookers and similar. I even came across 3 phase night storage heaters.
    The 3 phase shower in my friend's small Dusseldorf flat was 18 Kw until it developed a fault and for a few minutes dribbled a shower of molten plastic.
  9. Steve
    Steve
    15 Apr 2005
    16,478
    Thanks Received:
    244
    Yorkshire
    Country:
    What about in 1973? :LOL:
  10. bernardgreen
    bernardgreen
    3 Nov 2006
    23,783
    Thanks Received:
    2,294
    Bedfordshire
    Country:
    The new one in my friends flat was 3 phase in 1973 :evil:
    And there is probably even more 3 phase domestic installed now in this year of 20xx
  11. Adam_151
    Adam_151
    17 Jun 2004
    6,600
    Thanks Received:
    259
    Country:
    And from what I understand reading the IEE forum is that prospective fault currents are lower on the continent... well if you've only got a max of 30A/40A fuses even for the service fuses, then it doesn't matter if your PFC is not a handful of KAs! Apparently equipment thats pretty reactive that works fine over in germany may suffer from its power switch burning out over here due to higher inrush! (which was the subject of the thread)
    Oh in ref to the OP, and its 4-wire, not 5... we only generally only count the live ones (which includes neutral) ;) The good news of course, is to get a 400v shock you have to be quite careless and touch two things that you shouldn't as opposed to just one for 230v :)
  12. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
