Hi all I’m changing my boiler and I’ve just had a new flat felt roof, the flue is a vertical flue approx 500mm from neighbours wall. The current boiler is a valiant boiler, can the existing flue be used for the new boiler eg veismann or Worcester bosch or valiant, or do all new boilers need new flues? Because if I need to change the flue I have to redo parts of the felt roof? Any advice would be great thank you, I know different boilers come with different vertical flue kits
Oh no, thought so thanks, how about the positioning if it’s 500mm away from the wall can i use the same hole in the roof? Or does flue need moving even more away from wall? Thanks
