I have a Gainsborough 8.5 shower. When trying to adjust the temperature it will come very hot or, if turned towards cold it will come too cold. I am not able to ajust it to a comfortable temperature.
I suppose it depends what the faulty part is and how economical the repair would be.
When you turn the dial it just alters the flow rate of water through the heater, slower the flow - warmer the water, faster the flow cooler the water.
The heater should give a constant heat.
If you set the dial to a desired temperature, does the temperature fluctuate? Does the water flow fluctuate?
If I turn the control fully to the hot ,the water flow does slow down and the waterb is red hot. When I turn to cold, the water flow is faster and the water goes cold. My problem is I cannot get a comfortable temperature, Its' either too hot or two cold. Should I adjust the water input, ie reduce or increase the pressure.
