    Dismiss Notice
Cantilever support of RSJ
Discussion in 'Building' started by Dave337, 14 Aug 2019.
  1. Dave337
    Dave337
    14 Aug 2019
    Thanks Received:
    Country:
    Just after a spot of advice. We are having an kitchen extension done (knocking out an external wall (c. 5m)) and have an RSJ across gap. Will be resting on single 100mm brick and supported in the centre by an existing perpendicular cantilever RSJ supported by a pillar. My question is - in the plan the pillar is too close to the future external kitchen wall. Structural Engineer calcs I'm sure are all valid etc. I'm just after theoretical ways that the pillar could be moved further back (ie away from new RSJ). Would having thicker columns for the new RSJ to rest on reduce load in the centre and allow the move? Or would thicker steel in RSJ or pillar allow a move?
    I will be speaking with architect and SE tomorrow - just curious on general rules / logic.
    Dave
  2. blup
    blup
    5 Nov 2007
    992
    Thanks Received:
    143
    Country:
    Rather than move the pillar you could ask if it is feasible to do away with it altogether and spec a larger beam in the new opening with the 4 inch brick upgraded if necessary?
    Blup
  3. tony1851
    tony1851
    23 Feb 2012
    9,229
    Thanks Received:
    1,384
    Manchester
    Country:
    Are you saying that the 5m beam is being partly supported off a cantilvered beam, which is in turn supported by a steel column?
    Hard to grasp your layout - can you post a plan?
  4. ^woody^
    ^woody^
    3 Sep 2006
    26,845
    Thanks Received:
    3,333
    West Mids
    Country:
    Yeah, a plan and a couple of nurofen.
    • Like Like x 1
  5. Leofric
    Leofric
    9 Nov 2018
    1,668
    Thanks Received:
    139
    Country:
    Yes , one for your architect and SE I think.
  6. bernardgreen
    bernardgreen
    3 Nov 2006
    21,986
    Thanks Received:
    2,028
    Bedfordshire
    Country:
    A cantilevered beam is like a see-saw, any weight on the un-supported end has to be matched by weight or tie down at the other end.
    Not all builders know this .
  7. ^woody^
    ^woody^
    3 Sep 2006
    26,845
    Thanks Received:
    3,333
    West Mids
    Country:
    We leant this age 5 on the seesaw in the playground.
  8. bernardgreen
    bernardgreen
    3 Nov 2006
    21,986
    Thanks Received:
    2,028
    Bedfordshire
    Country:
    We did, but not all builders had access to a playground :mrgreen:
    • Like Like x 2
Loading...
Share This Page
