If you think your system is just a little down on pressure, why not try one of those top up canisters available from motor factors or Halfords?
John
John
£59.99 for the gas and £19.99 for the trigger assembly at Halfords.If you think your system is just a little down on pressure, why not try one of those top up canisters available from motor factors or Halfords?
John![]()
I did that recently with a mate’s Peugeot RCZ.If you think your system is just a little down on pressure, why not try one of those top up canisters available from motor factors or Halfords?
John![]()
Evaporator?Well took car back to same mechanic and he did a Dye test and said the evaporator is finished and showed me where the dye had leaked onto the ground. Said it would be £350 to repair. I didnt get my £60.00 back though. What are peoples thoughts?
If the mechanic used a machine to fill your system, the machine is automatic and won't refill the system with gas unless it can pull and maintain a vacuum to determine that the system is gas tight. Its quite possible that your system has just completely failed after it was refilled.Well took car back to same mechanic and he did a Dye test and said the evaporator is finished and showed me where the dye had leaked onto the ground. Said it would be £350 to repair. I didnt get my £60.00 back though. What are peoples thoughts?
Yes, this happened to my on an Astra.If the mechanic used a machine to fill your system, the machine is automatic and won't refill the system with gas unless it can pull and maintain a vacuum to determine that the system is gas tight. Its quite possible that your system has just completely failed after it was refilled.
It is possible but, more likely to be the condenser if it was leaking under the car.Thanks all, so it is not possible it was from the evaporator?
Where exactly had it dripped onto the ground?
Mines not worked for about 6 years, must get round to getting it seen to.
I leave ours on all the time, I don't think there's such a trade off regarding fuel consumption these days.
John![]()
