Didn’t know it existed.
And now required for grant
I think they should also supply the enclosure, then sure it is type tested.I kinda get your point about the rcd.
However if they didn’t supply one, would sparkys fit type A and dual pole? I doubt it! So this ensures they have the right stuff for the job. With no excuses
More important than minor busbar alignment issue in my eyes.
I would guess in a couple of years time they won’t supply Rcd. When stocks run out and type A more common and cheap
You can get it in Brown and Blue, nowadays, as well as the old grey.Are those Tails Single Insulated as if Double I'd expect the outer sheath to be Grey?
Those beatings might stop if you used 16 kA devices - since, as far as I can make out, it's only in that respect that a 'type tested CU' really differs from a non-type-tested DB.... It has been beaten in to us that we shouldn’t mix different maker’s devices in one CU. This apparently due to “type testing”.
And Black & Grey.You can get it in Brown and Blue, nowadays, as well as the old grey.
I do believe Red and Black was available but rarely seen.
I cringed when I saw thatBit reckless cutting one swa with a grinder like that especially with no quard.
