Cast iron soil pipes
15 Feb 2007
Cambridgeshire
I am trying to identify an adaptor to connect the waste of a modern toilet to a Victorian waste pipe. The waste pipe is difficult to access and therefore I am unable to accurately measure the internal diameter of the pipe which appears to be about 3" to 4" with a bell end diameter of approximately 6". Is there a standard dimension that I can assume to enable me to buy an adaptor :?
Do what they did in the old days and caulk it with cold lead rope :wink:
The cast iron will be 4", Multiwik do a range of pan connectors for cast iron
frenum or prepuce.........Prince Albert :shock:.......could be lead@ 3 inch
Many thanks for the advice. Having identified the connector I am trying to locate a supplier.
I suppose the 'bell end' description did invite a response. :)
You will probably need a 88mm adaptor. But there are a range of cast sizes around three i think. But 88mm is most common. it may only come as an extension piece which you will then need to put a standard pan connector into. Some branches of plumb center sell multikwik but any good plumbers merchant should be able to give you something for the job.
