    Dismiss Notice
Cavity Tray at DPC level vs lean mix infill
Discussion in 'Building' started by williamglossop, 17 Mar 2021.
  1. williamglossop
    williamglossop
    28 Jan 2011
    330
    Thanks Received:
    23
    Manchester
    Country:
    I'm seeing more and more use of cavity trays all the way round a build at dpc level rather than two level DPC's (inner/outer leaf) with angled lean mix concrete.
    Just wondering why things have changed more towards a massive tray all the way round.....
  2. Sponsored Links
  3. ^woody^
    ^woody^
    3 Sep 2006
    33,540
    Thanks Received:
    4,560
    West Mids
    Country:
    Things have not changed
  4. williamglossop
    williamglossop
    28 Jan 2011
    330
    Thanks Received:
    23
    Manchester
    Country:
  5. williamglossop
    williamglossop
    28 Jan 2011
    330
    Thanks Received:
    23
    Manchester
    Country:
    Why would one method be used over the other...
  6. ^woody^
    ^woody^
    3 Sep 2006
    33,540
    Thanks Received:
    4,560
    West Mids
    Country:
    The only practical reasons would a difference in internal floor level, or a radon barrier
  7. noseall
    noseall
    2 Feb 2006
    42,860
    Thanks Received:
    2,652
    Staffordshire
    Country:
    The brand new home we are working on at present (Redrow Homes) has trays all round at DPC (B&B floors). I can't see any reason why the addition and it's deffo not a radon risk area. Builders must be steering away from sub DPC cavity filling perhaps in favour of DPC level trays..?
  8. ^woody^
    ^woody^
    3 Sep 2006
    33,540
    Thanks Received:
    4,560
    West Mids
    Country:
    Lose fill cavity insulation?
    • Thanks Thanks x 1
  9. stuart45
    stuart45
    13 Sep 2008
    3,139
    Thanks Received:
    482
    Somerset
    Country:
    With wheelchair access being required, ground levels need to be higher, (which requires a tray) is another reason.
  10. Sponsored Links
  11. noseall
    noseall
    2 Feb 2006
    42,860
    Thanks Received:
    2,652
    Staffordshire
    Country:
    Probably. Why would it matter having sub-dpc lean mix cavity fill though?
    Have you seen how the brickies keep the cavities clean these days Woods?
  12. ^woody^
    ^woody^
    3 Sep 2006
    33,540
    Thanks Received:
    4,560
    West Mids
    Country:
    It's been a long long time since I've seen any proper brickies working
  13. noseall
    noseall
    2 Feb 2006
    42,860
    Thanks Received:
    2,652
    Staffordshire
    Country:
    They lay hessian sacking in the bottom of the cavity, build the walls then smash out every third block and drag out the snot covered sacking.
    • Like Like x 1
  14. ^woody^
    ^woody^
    3 Sep 2006
    33,540
    Thanks Received:
    4,560
    West Mids
    Country:
    :eek:
    Bloody radicals
  15. 23vc
    23vc
    17 Apr 2015
    2,505
    Thanks Received:
    398
    Warwickshire
    Country:
    Is there no insulation in the wall at that point then? That sounds a right b4ll ache
  16. noseall
    noseall
    2 Feb 2006
    42,860
    Thanks Received:
    2,652
    Staffordshire
    Country:
    I think the idea was contrived with partial fill in mind.
  17. noseall
    noseall
    2 Feb 2006
    42,860
    Thanks Received:
    2,652
    Staffordshire
    Country:
    Indeed.
    I showed my young oppo the blocks that had been replaced, when we recently did an outer skin knock-down.
    A lot of effort but I do agree with it. I have seen snots stacked up to the third course above DPC, filling the (50mm) cavity.
Loading...
Share This Page
