CCTV Camera Problem
24 Dec 2009
Northamptonshire
I have 4 Day/Night IR dome camera's fitted to my house. The camera's have worked well for 6 weeks but in the last 6 days a problem has occured. As it starts to get light in the morning the image begins to go white and eventually goes comepletely white. After a while it'll go back to normal and be perfect image again. Might be a coincidence, but it all started when we had a load of snow whitch is still on the ground.
Anyone got any ideas?
THanks
It'll probably be the auto white balance which is a bit slow to react with the image being so bright.
It should settle down again when the snow clears.
it is snow problem in camera and you can check it again in morning snow fall.you can find the conclusion
