Hello
just a quick post here.
I currently have a small problem with my drill driver (that I use as a screw driver mostly). It’s the wickes version of CDT212W model. The chuck keeps getting stuck to the point I have to put in a vice and use pliers to undo it. A few days ago, I remembered that we have a spare chuck, and should work well, if I have done my rese right. Going from a 10mm chuck to 13mm bit opening.
Anyway, I have removed the screw inside the chuck but that has virtually no head (why?) and watched about 20 videos if not more on how to remove the chuck, and I have tried to apply this to the drill but just can’t seem to do it… can you help with tips etc?
btw. I have never been good with the whole righty tighty lefty loosey. When doing something clockwise or anti-clockwise does that mean as the drill faces you or away from you?
my main confusion of lefty tightly, if you look at a clock, the minute hand from 6 goes left (clockwise) however if you do anti-clockwis, and have the minute hand at 12, the minute hand goes left… so basically if you can please just use clockwise or ant-clockwise that would help loads.
thank you
thank you
